Indeed, there isn’t a ‘merge’ operator. But this is toolbox. We don’t have a 'putUpShelf() function but we do have a drill, and screwdriver and a spirit level, etc. So with the latter in mind…
The general pattern here, is to merge attribute MyY with attribute MyX values and then delete MyY. So we make
- an agent to find all notes with a value for MyY, i.e. query is:
$MyY
- code to merge MyY into MyX. Take care if either MyX or MyY is intrinsic as you’ll need to merge the originals’ values and not the aliases.
- once done and checked, delete the agent and then delete user attribute Y. If you do use attribute descriptions, consider updating MyX’s description to include any new MyY-related aspects now stored in MyX.
How about the merge?
Merging two String-types:
$MyXString = $MyXString + $MyYString;
You might want to add a join string, e.g. " :: ":
$MyStringX = $MyStringX + " :: " + $MyStringY;
The top might merge “Green” and “Ham” to “GreenHam” whereas the second would give “Green :: Ham”. You could also put the Y value first:
$MyStringX = $MyStringY + " :: " + $MyStringX;
giving “Ham :: Green”.
Merging into a Set-type:
$MySetX = $MySetX + MySetY;
As the recipient is a Set-type duplicates are removed for you.
Merging into a List-type:
$MyListX = $MyListX + MySetY + $MyListZ;
$MyListX = $MyListX.unique;
If necessary you could sort the MyListX list as well.
Adding a String type to a Set or list:
$MyListX = $MyListX +$MyStringY;
or
$MySetX = $MySetX +$MyStringY;
…and so on.
Does that help. Don’t forget to delete the merged-and-not-needed attribute_but_ only after you’ve checked the merged data looks right!
