Can’t I use the Mac finder to preview tbx files?
No. The image you see in Finder’s Get Info pane is of the View pane at save/close. However, I don’t believe there is a method allowing quicklook to see deeper into the file.
FWIW, ‘preview’ is a slippery term here. In a TBX with a few notes and no agents, action code etc., and using no Displayed Attributes, then previewing a note might be as simple as its title and body text. In reality, many docs are much more complex so you can’t ‘just’ look at a note and see what you see in the app. I assume this is why Finder/quicklook shows the information it does.
If you just need to see the data, simply open the TBX in BBEdit or the like - the TBX is simply a large well-formed XML document so can be read as XML (though the rich text aspects of $Text are stored in a further encoded in Base64 format (see). Inline images in text are stored in the rich text data.
What would you like Finder to show you?
If you are looking to search inside TBX files FoxTrot Search is AWESOME!! @TomD turned me on to it. Love it. Helps you peer into and search TBX files.
I didn’t explain it well enough. This is what I meant by the preview icon.
Just paid for the personal version - very impressive - thanks for the reference
