Sorry - this must be easy to fix - but I don’t find the right door…
I try to different ways to include an image to a note that is using the Markdown prototype:
<img src="/Users/anyuser/Desktop/Screenshots/Bildschirmfoto 2021-11-01 um 16.56.54.png" width=50px>
{width=50px}
both will not show an image in preview. I got an older demo from Michael Becker and the same code shows the image (the HTML version does, the Markdown version asks for a pandoc file I don’t have).
So there has to be an attribute I forgot to set (HTMLPreviewCommand = CommonMark)?!
To insert an image in markdown, in a given context, inserting an HTML img src will work. The more reliable way is to use the markdown syntax for an image: .
If you use Pandoc as the rendering engine, I’ve found that it will display the caption. I’ve not gotten the caption to work with Commonmark or Markdown engines. The image size {witth=" "} is also consistently rendered across the different engines.
