Hello,
Usually, outliners expand all nested items with command+control+0
But in tinderbox, I don’t see any keyboard shortcut for expanding all.
Could you please help me with the appropriate shortcut?
Thanks
Hello,
Thanks
It’s near the bottom of the View menu.
By default, we don’t assign a shortcut key. You can do this yourself in System Preferences, of course!
Actually, the ‘expand all’ shortcut does expand the entire outline, you don’t need to add one. Thus, ⌘+⌥+▸ (⌘+⌥+click container disclosure triangle) on any closed disclosure triangle will expand the entire outline. Similarly, ⌘+⌥+click on any open disclosure triangle will collapse the entire outline.
To expand/collapse only the current branch use Opt+click on the triangles.
For an exhaustive list of Tinderbox’s shortcuts, see here: Reverse Look-up Map
In principle, View ▸ Expand All could have a keyboard shortcut that wouldn’t require any clicks at all. You don’t even need to have a selected note.
I suspect that Expand All/Collapse All are lightly used. Then again, perhaps they’re too hard to discover.
