When I switch to map view (from any other view), I’m often presented with a blank screen. I have to scroll to find the notes. Is there a way to cause Tinderbox to navigate in the map to the note that was selected in the outline? Thanks.
In short, ‘No’. But if you know the name of the desired note, you can use Blind typing in view window to make it be selected and scrolled into view.
I’m not suggesting the latter is what you wanted/selected, yet it does work at present,
That will do. Thanks again.
