Hello everybody!
There are 9 notes in my container, but the SiblingOrder attribute indicates 12 notes.
I use $Subtitle=$ChildCount in Map View and it indicates the right number of notes, 9. Would I miss something? Thank you for your help.
Hello everybody!
I see ten notes!
Not sure what’s going on here.
You don’t show the whole outline, but is 12 is the value for the container of the other notes? If so, it means it is 12 of its own set of siblings. By way of explanation:
That’s it. I’m sorry. I made a mistake: I thought that 12 was the number of notes my container had whereas it was its outline number! Nothing irrational!
