I have a stamp $Source=$ID(parent)+"#"+$Name(parent);
This works perfectly, unless it is applied to an alias, at which point it takes on the name fo the alias and not the original note. Is there a way to combine orginal
and parent
designators?
e.g. $Source=$ID(original,parent)+"#"+$Name(original,parent);
[NOTE: this is an example, is not correct and does not work].
