Is the bottom the only place where Park Link appears in Map View?
If another note is composite under the note, it will not be visible.
No problem - terminology isn’t always obvious . OK, so Link stubs are fixed, they:
- can’t be deleted
- outbound stub, if present, is always below the note
- inbound stub, if present, is always above the note
Does that help? If you need these stubs to be moveable, i’d suggest sending a use case and feature request to Tech Support (tinderbox@eastgate.com).
