sectionCloud question
Hello,
I have a document with notes and agents. I use the agents to filter my notes.
If I use sectionCloud on the notes folder all looks well, but if I do the same on the agent folder, sectionCloud does not seem to look into the aliases listed in the agent.
Can you see anything obvious I am missing? (test document enclosed)
Regards,
Philippe
Cloud.tbx (124.8 KB)
Testing, by adding an alias of a note stored elsewhere into the /Text container, the top test in your TBX doesn’t include words found only in the alias’ $Text.
This suggests aliases are ignored—perhaps by original intent. Still, the feature goes back to v3.5.0 in 2006(!). Perhaps it broke in the app codebase re-write going from v5 → v6? Anyway, it’s many years since I recall any discussion of the feature.
@mwra - thank you, I’ll adjust my usage of the cloud feature.
Regards,
Philippe
  1. The GetInfo word clouds are better,
  2. The export operator does ignore aliases; this will be corrected in the next release.
@estgate - Thanks:)
Regards,
Philippe
