I have a map with several Smart Adornments. I would like to write a Smart Adornment query, I think, using the “if” condition. What I want is: If a note is already included in a Smart Adornment, I want it to not be included in the query. IOW, I do not want one Smart Adornment to be in conflict with another over the same note.
Good suggestion. IOW, have an attribute like $AttributeDisabled=true to function as an on/off switch. Will give it a spin. Thanks for the suggestion Michael
I did not know this until now…makes the above rather mute…
A note on the map can only move onto one smart adornment. In the case of conflict, where two or more smart adornments match a given note, the adornment with the highest$OutlineOrder will match the note. An adornment’s $OutlineOrder can be looked up via its Get Info pop-over (attributes tab: General section). Normally, a duplication conflict resolves to the lowest outline order but in adornments the z-order and thus outline ordering is reversed (further explanation).
