Some corrections to tagger document in atbref
Hi @mwra:
I’ve been incorporating taggers into a few projects. I have been working with some short multi-word phrases and learned that these don’t work if they are quoted:
In the Tagger Syntax section:
Terms and multiple words. Unlike a tag, a term may be a multi-word string (e.g. 'first-name last-name'). Note, however, that this style of term is not intended for matching long texts (there is no fixed limit, just use multi-word terms sparingly)
I took this example quite literally. Once I removed the quotation marks things started working.
and a minor typo in main section Taggers:
Term matching and case
A tagger's defined terms are matched case-intensively in any note's $Text. Thus a term Tinderbox with match both "Tinderbox", "tinderbox" or any other case variant of the word.
Thanks for this excellent resource.
Both fixed. :slight_smile:
To help me help all of you (readers of aTbRef) it helps massively is you give the URL of the page with an error. On first check the reports above didn’t (in-app) give an unambiguous target note. I managed traced the errors to here and here.
Another polite request: please report all errors on the page. Reading (before fixing) (Taggers) and [here] is is clear the illustrative image is missing as aTbRef uses no $Text-embedded images and have one or zero images per page (note). So, this us easy to check by looking at the page (of which the overall site has c.2.5k pages, so not easy to check en masse). Thus if images change, pages making secondary use of another pages image—as here—can miss the update.
The first issue re tagger syntax is resolved using ‘code’ formatting’ rather than quotes to indicate the literal code in the article. The learning point for me is different readers parse use of quote differently. No judgement there but a reflection on the ‘Curse of Knowledge’† when making assumptions as to how age reader interprets them.
†. Curse of knowledge: Colin Camerer, George Loewenstein and Martin Weber, “The Curse of Knowledge in Economic Settings: An Experimental Analysis”, Journal of Political Economy 97(5), 1989, pp. 1232–1254.
:+1:
more thorough reporting will be done next time !
Thank you
