Hello everyone!
I’d like to remove an error message that appeared after deleting a hints and export containers.
How could I do that? Thank you!
Set $HTMLExportTemplate of /Timeline/Plan and /Prototypes/ProtoNote to “”. You can do this in the Inspector:
With respect to clearing the error list, if the cause has been fixed, the message should self clear after a bit.
Double-clicking on the listed item should focus on that note or (if already corrected) simply dismiss that message from the queue. Failing that, re-open the doc.
Resolved! Thank you!
