The clean up feature for notes is very helpful.!
Is there a field to clean up in the order in which they are “added timing into the Container”?
“OnAdd” did not work.
I use the Containers to keep the screen clean by throwing processed notes into the Containers.
So when I organize them later, I want to arrange them in the order in which they were put in the Containers, not in the order of Created, Modified date or Name.
If you want to do this for lots of containers, make a container with the above settings, move it to your Prototypes container (ensuring it becomes a prototype) . Then, whenever you need a new ‘sorted’ container, you can use the prototype.
Or, if you need to use prototypes for other purposes, this stamp will set up the container settings needed:
$OnAdd = '$SortDate = date("now");';
$Sort = "SortDate";
// uncomment next line for newest first
//$SortBackward = true;
Note the last option (re time=-based sort order) is commented out—see discussion of this point further above.
It works, but the newest one is left… is it possible to make it the newest one right side? (when I clean up them row)
(left to right like the nomal time line)
Do you mean in map view? What clean-up layout are you using?
Tip: for things like sorting, even in maps, first make it work in outline, then map and other views should work. The outline order ($OutlineOrder) informs all views.
I assume the map clean-up uses the outline container sort order, i.e. $OutlineOrder. So the first listed will be top left of [whatever layout] grid pattern you use for clean-up. How the rest follow will depend on the pattern you choose.
Did you not try the reverse sort ($SortBackward) option I described in my previous post? Does it not change the clean-up order?
@eastgate has kindly confirmed, elsewhere that clean-up:
uses $OutlineOrder
progress goes left to right, top to bottom, i.e. as in writing on a page in a European-type left-to-right language.
a box layout starts top left and then orders clock-wise back to the start.
As a result have updated Re-arrangeable Agent Maps and Cleanup Action pop-up list. The former explicitly mentions that the ‘reverse’ box on the Sort Inspector is way to reverse sort order as it might not be self-evident to the newer/less-experienced user. See the per-data-type child notes to this article for per-data-type default sort ordering.
