Split note shortcut
Hello,
I am trying to split a large document into sections.
  • I position my cursor in the text area and type: [Cmd]+[Opt]+[Ctrl]+Return and nothing happens.
  • If I Select Menu/Note/Split, all works as expected.
  • I checked keyboard maestro and I don’t think I have that key sequence used + tried after stopping Keyboard Maestro.
DB enclosed - I position my cursor before a “####” on the next #### &61. line
Flying.tbx (2.6 MB)
Any advice on how I could troubleshoot this?
Regards,
Philippe
PS: Perhaps related: As I go through the process, I notice some notes appearing in my Prototypes container (enclosed)
Flying.tbx (2.7 MB)
I suspect you want to turn off New note name parsing for prototypes and locations.
@mwra - Thank you - question #2 seems answered / no new prototype since I unchecked that option.
Regards,
Philippe
Works for me here, using the specified shortcut. Result shown:
However, , the more normal Tinderbox approach to this sort of import would be to use the Explode feature: see Exploding Notes. That avpids needing to use the split function.
My test looks sutup selection was like this, and it worked.
Depending how clean the source is, in terms of sections starting with the note-to-be title’s text, you ought to get a very clean extract to note in one explode. Note you may find it easier to make some light editing of the source if you don’t get the titles you want.
It shouldn’t impede here as Markdown rendering is off by default. But, if you are a Markdown aficionado, I suggest you don’t turn on the Markdown support until you’ve done the explode and lost all those #### character runs which look like Markdown H4 markers! Different people do very different things in Tinderbox so not all defaults suit all users, q.v. the prototype/location auto-detection described above.
Also, Tinderbox generally expects to work with smallish notes in terms of amount of text. There isn’t a limit but the fact selecting your test TBX’s ‘Part 61’ note is quite sluggish suggests this is an excess. so, once the import is done I’d either delete the $Text of 'Part 61" (first saving somewhere outside Tinderbox if still needed as one text). Or, after moving out the explode-generated notes from under ‘Part 61’ just delete the note. Look up the aTbFef notes above on Explode to see the purpose of the ‘exploded notes’ sub–container created by an Explode.
@mwra - Thanks again.
Not quite sure why the shortcut does not work but your solution makes it less of an issue.
I have not touched Markdown options on this document so I should be ok.
I had looked at explode but not noticed the “break at delimiter” feature. I just applied it on another Part and it worked:)
I do delete the complete document when I am done - I noticed long documents can be slow to manipulate.
Regards,
Philippe
If the shortcut doesn’t work it is likely another app has ‘taken’ that shortcut. This occurs because (to the best of my understanding) when an app starts it signals to the OS the shortcuts it needs. So, after a macOS session boots up, it is first-come first serve. As munmu-bar apps are often opened as post start up they are the best pace to look. For instance I use to have a problem with Browse Links shortcut until I discovered 1Password also mapped it and 1Password always opened first.
Surprisingly, it there is no simple Mac report that tell us which shortcut is mapped to which open app.
So fixing the issue, it is a two step process. Find the app already using that shortcut and if possible delete or re-map the shortcut. Otherwise close it and re-open Tinderbox before re-opening the other app. Or make a custom OS shortcut to use a different shortcut to call Tinderbox’s split.
@mwra - You are correct, I had my eyes on Keyboard Maestro but it was a shortcut I had made long ago in Magnet.
Sorry about that.
Regards,
Philippe
No worries, the ‘missing’ shortcut is always a head-scratcher at first encounter. :slight_smile:
I find it useful to have Shortcut Detective installed. It is ancient and will crash every time, but it still solves a few mysteries.
It has always seemed that OS X / macOS should have a shortcut-conflict discovery app, because obviously the OS knows about the conflicts, but keeps it secret. KeyCue can help with discovery, but not with conflicts. ShortcutDetective is excellent, and slowly dying.
