Target for bargraphs
Hi,
I can set up a container plot on an agent to show the number of books read per year, using a bargraph:
The Inspector panel has a field for target, to draw a line in the plot colour across the graph. The field accepts a value ($Pattern=bargraph ($ChildCount,0,100,52)), but no line is drawn.
However, it does work when plot is used instead of bargraph.
Am I doing something wrong, or is this intended / inevitable? Or perhaps something that just hasn’t been implemented yet?
Thanks!
I hadn’t thought about that! It’ll be in the next backstage release.
That’s great – thanks, Mark!
@eastgate
Good grief, that was quick!
I only asked the question last night, then I downloaded the new version 11.7 this morning and you’ve already implemented the change…
Perfect – thanks very much!
