satikusala
(Dr. Michael Becker)
May 21, 2021, 5:41pm
1
TBX Tip: Copying & editing embedded RTF links
In the $Text highlight the linked text, and only the linked text, and then ctrl+click. This this will open up a pop-up menu. Select the Edit Link menu and the edit link pop-up will open. From this pop-up you can copy the link destination (aka link) or remove it.
Figure: Edit RTF Link Menu
Acknowledgement: I learned this tip from Sumner Gerard @sumnerg .
Data
(Data Architector)
May 23, 2021, 12:28pm
2
satikusala:
Let everyone know in which version of MacOS and Tinderbox this is possible
satikusala
May 23, 2021, 5:03pm
3
I think this is fine in at least 8+, maybe earlier, can’t be sure. As for macOS I don’t know there either. Maybe @sumnerg does.
sumnerg
(Sumner Gerard)
May 23, 2021, 5:23pm
4
I’m on v. 8.9.2 running on Big Sur 11.3.
I think it was working on Catalina but can’t test that.
I believe @mwra said the Edit Link... does not appear in the contextual menu in an earlier version of the MacOS.
mwra
(Mark Anderson)
May 23, 2021, 9:32pm
5
It certainly is not there in Mojave 10.14.6
pmaheshwari
(Prashant Maheshwari)
May 23, 2021, 9:39pm
6
This feature doesn’t work on Catalina on 8.9.2
It works fine on Big Sur on 8.9.2
