Tinderbox Action Code LSP ( VS Code Extension )
I have released the Tinderbox Action Code LSP , a VS Code extension.
I built this extension as a winter holiday project.
completion
It was built using “vibe coding” with Gemini Cli and Antigravity. The language is automatically detected when the file extension is .tbxc.
It should function similarly to a standard LSP. For the hover information, I am using Mark Anderson’s excellent “A Tinderbox Reference File”,and I would like to express my sincere thanks to @mwra.
It might still have some bugs, but it currently supports features like checking for missing semicolons and smart quotes. Please feel free to give it a try.
:pray: I’m glad the reference was of use. It is my intent, but I can only guess how it works for others :slight_smile:
If use finds any errors in my docs, reports are gratefully received as it is meant as a community resource and needs to be as correct … as it can be.
Happy New Year to all.
Amazing, thanks!
I have pushed several major updates up to the latest version (v0.3.2). Here are the key new features and improvements:
  • Full Export Code Support (.tbxe): The extension now fully supports Tinderbox Export Code. It provides rich autocomplete, hover documentation, and robust parsing for Export Tags (^...^), gracefully handling nested structures and complex strings within tags.
  • Token-Based Parsing Engine: The core parser was upgraded from simple regex scanning to a robust token-based state machine. This massively improves the accuracy of Signature Help, Hover documentation, and context-aware variable scoping—especially for complex method chains and nested parentheses.
  • Workspace Symbols: You can now use Cmd/Ctrl+T to search for user-defined functions and variables across all open documents in your workspace.
  • Code Actions (Refactoring): Added a Quick Fix (Cmd+. or Ctrl+.) to easily “Extract to variable” from a selected expression.
  • Enhanced Snippets & Semantic Tokens: Added specialized control flow snippets for Tinderbox (e.g., each, if blocks) and introduced distinct syntax coloring for read-only system attributes.
You can find the extension on the VS Code Marketplace and the source code on GitHub:
Very nice! It would be great to see a demo of this at a meetup sometime…
Thank you so much for the kind invitation, and please accept my apologies for the late reply.
Regarding the meetup demo, to be honest, I am not very confident in my English skills and I tend to be a bit shy when it comes to public speaking. It feels a bit too much for me at this time.
I hope I will be able to do it someday…
Thank you for your understanding.
