This appears to be almost self referential in that the list ($Character) is being scanned for what appears to be the list ($Character). Clearly that’s not the case. The “pattern” appears to be qualified by the addition of (agent) but in searching around I don’t see any reference to this type of qualification or how it works.
Any pointers to where to find a reference would be appreciated.
The query here unpacks as: "does the string in attribute Character march wholly or in part, case insensitively, the value of the attribute Character as stored in the agent.
This trick makes it a simple as showing the attribute Character as a Displayed Attribute in the agent. Now, every time you edit $Character ( the value of attribute Character) in the agent, the query changes.
I’m getting there but I wonder why the term “agent” is necessary, does it have some function.
Based on your explanation my pedestrian understanding is:
The query looks at the value in the character attribute of the agent and searches other notes in the Character attribute for a matching value. Since this is a query associated with the agent I’m wondering why the apparent “qualification” of agent is needed. On the surface it would appear to be unnecessary.
I ask because I always find Tinderbox very unforgiving and so it helps to know exactly what needs to be specified.
When you refer to an attribute’s value (e.g. $Width), you implicitly are asking about the value for this note, $Width(this).
In an agent query, this is bound to the note being examined. If an agent is looking for notes that have $Width>10, it examines each note in turn and asks, “It this note wider than 10 map units?”
But sometimes, a query needs to compare each note to a value stored in a specific note. For example, we could look for notes where $Width>$Width(/Example) – all the notes that are wider than the Example note.
In Michael Becker’s example, he wants to examine the value of $Characters, looking for a specific character that is stored as the value of $Characters in the agent. Just as this designates "the note we’re examining, agent means "the agent whose query we’re evaluating.
As @eastgate has suggested it is a method of saying, for attributes, “give me the value of attribute named X, but for note ‘XYZ’ rather than the note I’m currently assessing.” In a wider sense it allows action code and export code to address predictable targets like “my children” or “my child number N” without having to write a more bespoke query. Consider, the item ‘C’ under path A/B/C in the outline (the canonical source form of a Tinderbox document band as see in Tinderbox’s outline view) is not the same as article C' at path A/B/D/E/C`.
