In the attached file, I created an agent that combines various random options for Proteins, Vitamins and Carbs at breakfast. It does this in attribute view. Where I need help is with locking off one option for in a group, whilst leaving the rest as variable. For example: let’s say I want to lock off “bacon” under proteins, but want the rest to randomly change, because I want to compare and contrast combinations. I don’t know how I would do that. The Tinderbox way I guess would be to export different combinations, but it would be nice to be able to view different combos side-by-side in one of the views, without exporting. Any suggestions on how to do that? Thanks. Breakfast Randomizer.tbx (100.2 KB)
Thanks to @mwra for the help in the TinderboxreferenceFile.
You can handle this cleanly by introducing a boolean like $Locked on each protein note and adjusting the agent query to exclude $Locked==true, which lets something like “bacon” stay fixed while the rest continue to randomize. If you move the randomization into a rule that only runs when a $Refresh attribute is toggled, you’ll get stable comparison states instead of constant reshuffling. Duplicating the container before each refresh would let you view multiple combinations side-by-side in Map view without exporting. It’s a flexible setup—whether you’re modeling breakfast options or planning a Cookout menu, you get controlled variability instead of total randomness.
