Using Tinderbox with The Archive
Hi, folks
Just getting started, and would like to integrate Tinderbox with software called The Archive, used to create a zettelkasten note collection. I’ve been using The Archive for years and am very attached to its simple elegance, but would like to see how using Tinderbox might add to it - especially in terms of creating visual maps of notes. Has anyone had any experience of doing this?
Many thanks in advance.
It should be straightforward to import your text files from The Archive’s archive folder to a Tinderbox container. That done, you can experiment with the map, Gaudí view, and also arrange things with the outline view.
Thank you! I’ll play around and report back.
