is there a possibility to get rid of a shape of a Note or hiding the Border, so that only the Text Title of a Note is visible?
Another question is related to a Shape in form of a Triangle. Is there a possibility to achieve this? @Eastgate would be nice to have that kind of Shape as well.
Make the note interior and the note border the same color as the map background.
Obviously if either the note or the background has a pattern assigned, then this might not work. So, itās up to you to design the colors for everything on the map.
As far as the triangle shape. If you make the shape of a note the ātagā shape, you can drag the middle handle on the pointed side of the triangle toward the opposite side and that will collapse the shape into a triangle. The is not a lot of room for the Name however --but if you play around with the handles you might arrive at a pleasant arrangement.
If you have a note that is shaped and colored and bordered the way you want then make it into a prototype and those attributes can be inherited by other notes.
Even better than making the note match the background: set the $Color of the note to transparent!
Itās tricky to get text into triangles. The tag variant Paul Walters described might tide you over. Iād be interested to see what youāre wanting to do!
Agree, that clean-up is good. I was musing on the fact that what is āuntangableā as opposed to what is not is often unclear, before the fact, to most of us who donāt have a coding/network/graphing background. IOW, it can be hard to tell what canāt be improved.
Indeed, routing links to minimize intersections is quite an interesting and difficult problem. Finding the optimal answer is, if I recall correctly, NP-hard ā which is to say, computationally intractable. Finding an adequate answer proved too hard for practical maps when last I looked. But that was some years ago; I hope to have another look at the problem.
IĀ“m sure this would be valuable!
My Exploration Thought Process starts often with a kind of Mindmap. One Main-Topic and a couple of Sub-Topics. At this phase, it should be possible to automatically arrange links without intersections.
But I know from experienceā¦ Often the simple-looking things are difficult to achieve.
Thanks to all for helping with this Topic!
There is some discussion here on suggestions for future Tinderbox link capabilties. For situations with just one main topic and a few sub-topics these would be overkill. However, if your mind map expands and becomes more complex I would expect some of the ideas expressed like visualising only parts of the tree, showing only certain link types and other filtering options could also be useful in your context.
