I’m relatively new to Tinderbox, and have mostly worked in its Outline view. But I was hoping to try it out for a projects that I’d like to structure in the Maps view.
Basically, I’m trying to put together a project that shows how a certain set of people belong to different groups, organizations, and businesses – but with different job tiles for each of these different entities. I’d also like to share this with colleagues, so this should be exportable in a format that they can see and use.
At first, I tried to set this up in Outline view by creating containers and populating them with notes, e.g., notes representing individuals under the People container. The text within the notes contains some basic background info, and I’ve included URLs for the notes, too. I also started to create note-aliases for the people who belong to the different organizations, and was hoping to create links between them in the map view.
But I’ve quickly discovered several challenges that indicate that setting this up might be tougher task than I first expected, so I’m wondering if Tinderbox might not be the right app for this – or if I’m just overlooking some basic steps to to better structure this.
Some basic observations of challenges, and questions about how to resolve them:
When I look at containers and notes in the Maps view, I noticed that it doesn’t seem possible to create links between notes (in this case, alias notes) in containers. Is that accurate? Also, what kind of links should I create between alias notes?
In general, I don’t understand why it’s hard to view and manage notes that are in containers, e.g., they’re often out of view and it feels like it takes a lot of curating to ensure that they’re visible. I’ve tried various things to in View > Arrange, but it feels like it takes several steps to ensure the visibility of notes inside containers. Are there some basic things I can do to ensure that notes visibly appear within containers, and won’t vanish and need to be re-arranged whenever I move or adjust the container?
I’ve tried to set up Adornments instead of containers, but of course those don’t appear in Outline. On the one hand, Adornments seem easier to work with for showing how individuals (represented in note-aliases), but I’m not sure if this is the best approach going forward as I toggle back and forth between Map and Outline view in setting up the structure of the people and organizations. I’m wondering what others in the Tinderbox community think is the best approach.
As I said, I’m trying to show “how a certain set of people belong to different groups, organizations, and businesses – but with different job tiles for each of these different entities.” I’m wondering how I ought to best set that up. For instance, would it be better to to just create job titles as Adornments, and put note-aliases of individuals on top of them? Or would it be better to create a key attribute for Title, and values for different job titles – and then create something like a hover expression that would enable users to see the different job title as the individuals appear in different groups, as they appear in different Containers / Adornments?
I’m open to any suggested approaches, and would even consider doing this in another app if Tinderbox seems ill-suited for this kind of project. Thank you very much.
