I’d like advice on how to proceed, as I’m half way through a problem.
The Goal: Write a book in Tinderbox, with footnotes that are written using the MultiMarkDown (MMD) format. My goal is to be able to move things to Word at the last step, as I prepare for submission to a publisher. I’m an academic. Word files are where it is at.
The Example: Simply put, I want to do is write a MMD footnote in my Tinderbox note.
**The format**: This is some text that I would like to be able to write in MultiMarkDown[^footnote1]
[^footnote1]: MultiMarkDown is a format from Flecher Penny.
When I do this in a text file directly, things render perfectly in Marked 2.
Yet, doing this in a Tinderbox note, rendering in Marked 2, it never seems to work as I expect. Instead, it produces the following.
After many years of being stuck at this point, this morning, I realized that what seems to be going on is that there is a collision between the ^export^ syntax of TinderBox and the caret symbol of the MultiMarkDown footnote.
My first thought was backslash the caret. \^ But that didn’t work. So, my first question. Is there a way to force the caret not to be interpreted as a caret by Tinderbox?
Fiddling around, I found a work around, and created a Tinderbox macro, that simply adds a [^
This means that the following text
** The format ** : This is some text that I would like to be able to write in MultiMarkDown ^do("fn")^footnote1]
^do("fn")^footnote1]: MultiMarkDown is a format from Flecher Penny.
renders perfectly, in Marked 2’s stream preview and even directly in Tinderbox!
As an aside, to get it to work directly in TinderBox, I installed MultiMarkDown from Flecher Penny’s site, then changed the HTML Preview Command to “/usr/local/bin/mmd” for the note. It’s is MMD bliss! So, far. I’m flying.
My question are threefold:
First, as a straightforward goal. Is there a way to write [^fn_1] and have it render in MMD correctly? Or, are Macros the way to go? Can I backslash a caret? Or, in some other way, make this happen?
Second, the macro I came up with feels like a hack, and is hard to read as a human in my text. Is there a better way to use such a macro? However, when I try to use a macro like:
[^$1: $2]
Tinderbox adds space after the caret, and I can’t get it to render properly in MMMD becuase the macro seems to produce:
[^ footnote1]: MultiMarkDown is a format from Flecher Penny.
- Third, and my main question, is there a way I should approach doing this more dynamically and automatically? What I’d like is to a creates links of type note in the text, and then have Tinderbox look up the note, intert its $Text directly into the note ready for reading by MMD.
In other words, do some HTML Export Template magic, so that this
Becomes
Which can then get passed to MMD, and be rendered in a Preview pane and in Marked 2,* and crucially so that I can export to word at a later date.*
I am insistent on using MMD for footnotes, because it is trivial to use pandoc to convert a mmd file into a LibreOffice file which is then trivial to important into Word, all while keeping the footnotes!
Why do I care?: I wrote my first book in Tinderbox. But, when I moved from Tinderbox to Scrivener or to Word, I had to recreate footnotes by hand. I’d like a better way of doing them, as I start a new book, that will become 200 pages. The publisher wants a simple word file, no formatting, but with footnotes.
What I’d like to be able to write, create footnotes in tinderbox on the fly, then have a pathway to get everything into Word. MMD seems the best way to go. But, maybe it’s a red herring?
Ideas on how best to work with footnotes. Crucially, I think, is there a way to change the anchor text of a link programmatically as the text is exported? If so, as a note is exported, the link anchor text could be converted into a MMD footnote? But, I’m stuck on how to even approach that.
Basically, I’m looking for ideas on which direction to proceed.
Best
Daniel
How are ^ caret characters treated in a note’s text. As I troubleshoot, I wonder if TB be eating the ^'s, thinking they’re export codes.
