I am curious to know if anyone here has experience accessing and manipulating notes and notes’ attributes using Ruby – in particular, using the Nokogiri gem (but not necessarily). I started playing around with this but didn’t make it far. The documentation isn’t particularly helpful, so I only managed to access some attributes, such as name and text, but not the other ones. I fear I might not be fully grasping Tbx’s XML structure and how it is supposed to work.
A minimal example:
#!/usr/bin/env ruby
# frozen_string_literal: false
Encoding.default_external = Encoding::UTF_8
require 'nokogiri'
file_path = ""
doc = Nokogiri::XML(File.open(file_path))
tbx = doc.children
items = tbx.xpath('//item')
p items[10] # just a random note, see below the result I am getting.
# attribute values
# items[0].xpath('//attribute').children
Random note
#<Nokogiri::XML::ElementElement:0x410 name="item" attributes=[
#<Nokogiri::XML::ElementAttr:0x3c name="ID" value="1624131850">,
#<Nokogiri::XML::ElementAttr:0x50 name="Creator" value="Bernardo Vasconcelos">] children=[
#<Nokogiri::XML::ElementText:0x64 "\n">,
#<Nokogiri::XML::ElementElement:0xa0 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0x78 name="name" value="Created">] children=[
#<Nokogiri::XML::ElementText:0x8c "2021-06-19T15:17:51-03:00">]>,
#<Nokogiri::XML::ElementText:0xb4 "\n">,
#<Nokogiri::XML::ElementElement:0xf0 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0xc8 name="name" value="DominantLanguage">] children=[
#<Nokogiri::XML::ElementText:0xdc "pt">]>,
#<Nokogiri::XML::ElementText:0x104 "\n">,
#<Nokogiri::XML::ElementElement:0x140 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0x118 name="name" value="Modified">] children=[
#<Nokogiri::XML::ElementText:0x12c "2021-06-19T15:17:51-03:00">]>,
#<Nokogiri::XML::ElementText:0x154 "\n">,
#<Nokogiri::XML::ElementElement:0x190 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0x168 name="name" value="MyString">] children=[
#<Nokogiri::XML::ElementText:0x17c "/DA/DA I/DA I 2 Opiniões dos predecessores/Predecessores/">]>,
#<Nokogiri::XML::ElementText:0x1a4 "\n">,
#<Nokogiri::XML::ElementElement:0x1e0 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0x1b8 name="name" value="NLOrganizations">] children=[
#<Nokogiri::XML::ElementText:0x1cc "Alma">]>,
#<Nokogiri::XML::ElementText:0x1f4 "\n">,
#<Nokogiri::XML::ElementElement:0x230 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0x208 name="name" value="NLTags">] children=[
#<Nokogiri::XML::ElementText:0x21c "κίνησις">]>,
#<Nokogiri::XML::ElementText:0x244 "\n">,
#<Nokogiri::XML::ElementElement:0x280 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0x258 name="name" value="Name">] children=[
#<Nokogiri::XML::ElementText:0x26c "Heráclito">]>,
#<Nokogiri::XML::ElementText:0x294 "\n">,
#<Nokogiri::XML::ElementElement:0x2d0 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0x2a8 name="name" value="SelectionCount">] children=[
#<Nokogiri::XML::ElementText:0x2bc "17">]>,
#<Nokogiri::XML::ElementText:0x2e4 "\n">,
#<Nokogiri::XML::ElementElement:0x320 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0x2f8 name="name" value="Xpos">] children=[
#<Nokogiri::XML::ElementText:0x30c "4">]>,
#<Nokogiri::XML::ElementText:0x334 "\n">,
#<Nokogiri::XML::ElementElement:0x370 name="attribute" attributes=[
#<Nokogiri::XML::ElementAttr:0x348 name="name" value="Ypos">] children=[
#<Nokogiri::XML::ElementText:0x35c "3.5575">]>,
#<Nokogiri::XML::ElementText:0x384 "\n">,
#<Nokogiri::XML::ElementElement:0x3ac name="text" children=[
#<Nokogiri::XML::ElementText:0x398 " Alma é o vapor. \n O que está em movimento percebe o que está em movimento. ">]>,
#<Nokogiri::XML::ElementText:0x3c0 "\n">,
#<Nokogiri::XML::ElementElement:0x3e8 name="rtfd" children=[
#<Nokogiri::XML::ElementText:0x3d4 "cnRmZAAAAAADAAAAAgAAAAcAAABUWFQucnRmAQAAAC4gAgAAKwAAAAEAAAAYAgAAe1xydGYxXGFu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\n\n">]>,
#<Nokogiri::XML::ElementText:0x3fc "\n">]>
