Markdown setup for DEVONthink users
For those that have/use DEVONthink there is a nice way to get a Markdown environment in Tinderbox. Enclosed is a template project file, intended to be the starting point for a Markdown project.
The changes to a standard TBX project are minimal;
  • ⌘-8 to turn of the curly quotes
  • modifying Tinderbox standard Markdown prototype to set $HTMLPreviewCommand=/usr/local/bin/multimarkdown
  • a modified style-sheet in /Hints/Preview/style
    That’s all.
    TBX with MultiMarkdown.tbx (126.7 KB)
Hey there,
⌘-8, for me, launches the document setting. Do you have a special hotkey set
Tinderbox, out of the box, support commonmark and markdown. Have you installed a multimarkdown package?
I installed a mulitmarkdown package form homebrew. Note, it conflicted with Discount and I needed to remove discount.
I thine needed to change the path as the path to my installation of markdown was not the same as yours.
After following the steps above, I got it working. Thanks. :slight_smile:
I think I made an error here. I thought that the multimarkdown-file in /usr/local/bin was part of the DEVONthink installation. This is NOT the case (looking in another computer). I’m not really aware of from where I got the multimarkdown installation from, probably here Releases · fletcher/MultiMarkdown-6 · GitHub.
Regarding ⌘-8 it was just for information on changes done to a stock TBX startup.
Cmd+8 opens Document Settings at the last-used tab (default: “General” tab). What you’re after is the Document settings ▸ Text ▸ Smart quotes. The Markdown render engine used is stored in $HTMLPreviewCommand.
The easiest way is to install it via homebrew (https://brew.sh).
Note that if you do use homebrew on M1 Macs, the path will be
/opt/homebrew/bin/multimarkdown
I think that the path is still /usr/local/bin on Intel Macs, but I’m not sure.
I got it from multimarkdown — Homebrew Formulae and got it working just fine .
Dear David Bertenshaw,
Thanks a lot for your MultiMarkdown’s information.
It works fine.
In my environment Intel mac (BigSur 11.7.5) PATH is still /usr/local/bin or
/usr/local/Cellar/multimarkdown/6.6.0/bin/multimarkdown.
Modifying Tinderbox standard Markdown prototype
$HTMLPreviewCommand=/usr/local/bin/multimarkdown works
$HTMLPreviewCommand=/usr/local/Cellar/multimarkdown/6.6.0/bin/multimarkdown.
Both settings are working fine.
I am in a hurry to report this.
Sincerely yours, WAKAMATSU
Homebrew made some changes when they updated brew.sh for M1 chips, and the change of the path for the binaries was one of them. I couldn’t remember the old path, so thanks for confirming that!
Yup, see this note:
