Tinderbox 7.3.1 is out
(Andreas Grimm) #1
Nice! Thank you, @eastgate, for this huge update.
Cheers!
Tinderbox v7.3 from DEVONThink Auto Import
(Paul Walters) #2
A note for DEVONthink users – the release notes for 7.3 regarding watching DEVONthink groups need a bit of explication.
Want to watch a DEVONthink group? Just enter the group’s URL in a top-level note’s DEVONthinkGroup attribute and Tinderbox does the rest.
Use DEVONthink On The Go on your iPhone or iPad to capture notes, and see your changes appear automatically in Tinderbox.
  1. The “Watched” sync applies to groups in your DEVONthink databases – not to documents. If you want to sync individual documents, you drag them from DEVONthink into your Tinderbox file.
  2. It is not the “group’s URL” that you need. DEVONthink users will understand the concept of the “Item Link” – which you can place on the clipboard by selecting a group and using Edit > Copy Item Link – the command is also in the DEVONthink contextual menu. To watch a DEVONthink group, create a note in Tinderbox 7.3, add the DEVONthinkGroup attribute as a key attribute from the Watched attribute category, paste the Item Link on your clipboard, and then delete the portion of that Item Link containing the characters “x-devonthink-item://”. It is very important that you delete those characters otherwise sync will fail. The content of the DEVONthink group you are syncing will appear as children of the container (note) you configured in Tinderbox.
  3. The content of child groups of watched DEVONthink groups will not sync – the process does not handle hierarchical groups from DEVONthink.
  4. Sync does not occur without some attention on your part. Your changes will “appear automatically” if you have synced that group from DEVONthink desktop (not DEVONthink Personal) to DEVONthink to Go, that the sync has completed on both the DEVONthink and the iOS device, and that the Tinderbox document(s) with the “watched” group(s) is open.
(eastgate) #3
Thanks, Paul.
One minor correction: responding to Paul Walter’s suggestion, the final release version will accept either a DEVONthink group ID or a DEVONthink URL. This wasn’t the case in the pre-release backstage versions.
(Andreas Grimm) #4
I do not get consistent results on this – either way:
No matter whether (in Tinderbox)
  1. I paste in (in DEVONthinkGroup) the entire link copied before (in Devonthink)
  2. or the edited link (= ID):
Sometimes Tinderbox reports this:
(A)
trouble fetching notesin DA23ED0B-EFE9-41C5-A2E2-1117DA2F1054
OR
(B)
trouble fetching notesin x-devonthink-item://DA23ED0B-EFE9-41C5-A2E2-1117DA2F1054
OR
it works just fine.
Ideas?
Cheers!
(Paul Walters) #5
@andreas, try again with a new Tinderbox document and using only the DA23ED0B-EFE9-41C5-A2E2-1117DA2F1054 portion (or whatever is relevant for your group) in $DEVONthinkGroup. I’ve found that once Tinderbox fails to sync a group, it will continue to fail with further attempts in that Tinderbox document.
Also, if the group that you want to sync with has child groups in DEVONthink, the sync might fail with the message you posted above.
(Andreas Grimm) #6
Exactly, @PaulWalters. I was just going to write that starting afresh with a new Tinderbox document and then using the edited link works just fine.
Thank you, Sir!
(Richard Pfeiffer) #7
Yes, thanks for the update! I’m really happy to be able to watch Notes folders.
One question I have is about the font information. I see that color info is included in the import, but not things like bolding, italics, or the font used in the original notes. Is it possible to include this kind of information in the import?
If so, is there any chance of adding it at some point down the road?
(Alex Strick van Linschoten) #8
7.3 = amazing. So much thanks for this version. So excited.
(Nick Gordon) #9
Not sure whether it’s clear from the release notes, but it seems that you can Watch an indexed group in Devonthink, as well as groups that are within the database.
(Nick Gordon) #10
I have a question about the new Watch feature:
  1. I create a top-level note and set its $DEVONThinkGroup to Group 1 in DT. Sync starts and the contents are imported
  2. I create a second top-level note and set it to watch Group 2 in DT. It syncs Group 1 (the same Group as linked to the first note)
  3. I see the same behaviour with File>Watch>Folder from Notes, but not with Folder from Finder
Is this expected? Is there a limitation on Notes and DT that one can only watch one item in any one TB document?
(Desalegn) #11
Wow, yes.
With Devonthink’s Smart Groups which hunt for files with specific finder tags, finishing up writing projects is simpler than ever.
(Desalegn) #12
Here is the a KM macro to automatically copy the Item Link and truncate the prefix.
(Desalegn) #13
And, the syncing (the fetching) is really fast. I like the new system very much.
One request for the next update: can the $Tags be fetched (synced) alongside the $Text?
(Andreas Grimm) #14
Cool, yet funky. Since it’s not working for me. I just get the system audio alert “Funk” when firing off the macro.
Ideas what I may be doing wrongly?
Cheers!
(Desalegn) #15
Probably you imported it into a macro group that cannot get Devonthink. Can you try to put it to a Global macro group. It is working for me. It is very simple macro.
And, make sure you selected a Group in Devonthink when you hit the key (CMD+alt+C).
(Paul Walters) #16
And here is an AppleScript that will do the same thing (put the UUID from a DEVONthink Item Link onto the clipboard for pasting into $DEVONthinkGroup in a Tinderbox container.
use scripting additions
property showDialog : true
tell application id "DNtp"
	set theSelection to (the first item of (the selection as list))
	if the kind of theSelection is "Group" then
		set the clipboard to the uuid of theSelection as string
		if showDialog then display dialog "Clipboard set to: " & (the clipboard)
	else
		if showDialog then display dialog "Not a group"
	end if
end tell
You can compile this and run it from DEVONthink’s Scripts menu. You can also include it into a KeyboardMaestro macro and not have to rely on GUI scripting as the other macro does.
(eastgate) #17
It’s difficult to get the style information out of Notes.app. We’re working on it.
(Desalegn) #18
@eastgate
is it possible to add the $Tags to the sync?
(eastgate) #19
We’ll look into watching $Tags from DEVONthink
(Eric Bowman) #20
For Bookmark items in DEVONThink, is there a way to get access to the URL in TBX?
For Markdown, Text, & eml, I’m able to see what I expect in TBX. But for Bookmark (and PDF, but that is maybe less surprising), I don’t see a way either to get at the data, or easily get back to the item in DT.
Total TBX noob here, so sorry if I’m missing something obvious.
Thanks,
Eric
