Release of Tinderbox “Package Management” system plus latest “Diagram View” package
This posting introduces a new Tinderbox “Package Management” system that I have developed with constructive input from @mwra and @satikusala along with the latest version of my “Diagram View” (see prior posting of initial “Diagram View”). Please note that this release requires Tinderbox 10.2.0 released on June 9, or later. @eastgate has introduced some significant enhancements in this latest version that have allowed this project to achieve its objectives.
Note that I gave a demo of the Package Management system during the Meetup on May 24 that may be helpful if you prefer a video overview. Also, the first version of the Diagram View application was presented during the March 1 Meetup.
The purpose of the Package Management system is to allow users to create collections of notes that can be bundled into a package and deployed automatically into other Tinderbox documents. For this approach to work, a standardized framework (the “Document Commons”) needs to be established in a destination document. However, the Package Management system can self-install this framework, and even update the framework and any included packages when new versions are made available.
Here is the new “Document Commons Framework” Tinderbox document that includes the latest Diagram View version:
Document Commons Framework v2•1•1e.tbx (12.4 MB) {Saved from Tinderbox 11.5.0 (b759)}
To make this trivial to deploy, a single copy-and-paste operation will deploy the Document Commons Framework along with any add-on packages into a destination document. While this will add essential items to the destination document, the current contents of the destination document will be unaffected.
To try this out, open the Tinderbox document provided above, and select the red Copy of “Document Commons” container as shown here:
Copy this container, and then paste the entire container anywhere into the destination document. That’s it! (It is recommended that you try this with a new or play document before trying this with any of your important documents, though I’m reasonably confident that nothing bad will happen.) The paste operation will activate a sequence of Installer code modules that will result in a new blue “Document Commons” container that will be the last top-level item in the document. It should look like this in Outline view:
In addition to installing the Document Commons Framework, the Tinderbox document provided with this posting (see above) will also install two add-on packages: (1) Diagram View and (2) Network Tools. This illustrates how multiple packages can be included in a single installation procedure. In practice, users could assemble (without any coding required) the installer for the Document Commons to include their own Packages, as well as Packages provided by others. The Diagram View is an example of an elaborate Package that provides an entire application within a Tinderbox document while the Network Tools is an example of a simple package with just some useful functions, stamps, and user attributes (useful to someone working with networks, that is).
There will also be an “InstallerLog” note placed inside the “LogBooks” container that will provide a detailed listing of everything the Installer procedure does, including the installation of any add-on packages.
A neat feature of this system is that a single package, or the entire Document Commons framework can be re-deployed into a document at any time. If there are any new items provided, then the Installers will properly update the corresponding items in the destination document, and move the outdated items into the “Discards” container. Any other left-overs from the installation will also be moved into Discards. Users can delete the Discards container at any time. In the case that an item in the document is newer than the item provided with the pasted installation, then it will be left as is. To try this, merely copy the red Copy of “Document Commons” container a second time into the same document. This can be done at any time, and provides a useful way to provide updates that can be replicated to one or more Tinderbox documents. The InstallerLog will detail exactly what gets done during updates.
Included with the Tinderbox document provided above are two ReadMe notes inside the Cover container that provide further details about the Package Management system and the latest version of the Diagram View. There is also a note that provides the Vision behind the introduction of Tinderbox Packages. Further documentation can be found throughout the provided Document. For example, select the blue “Document Commons” container, and the associated $Text entry provides a useful overview of this container and its purpose.
Also included is a “Playground” container that provides an example of a Diagram with a collection of notes that can be used to gain experience in creating and manipulating Tinderbox Diagrams. (Aside, check the ReadMe for Diagram View for an overview and a link to a deployment guide that explains how to complete the setup for the two required Link Types.)
While the technical approach taken is possibly interesting, the real intent is that this becomes something that just works, and that allows users to assemble and work with their own Packages without needing to know how it all works under the hood or do any coding.
I need to emphasize that this is a first release of the Package Management system, and there are some things that should be refined and enhanced in future versions. While it is pretty easy to build a package, and then incorporate a package as an add-on for the framework installation procedure, there are further improvements that can make this more reliable and even easier. And, of course, the documentation always seems to be incomplete.
What I would like to ask of this community is that, if you think Packages would be useful to you, then please take a look at the way that the Document Commons has been set up, and let me know if it is missing anything you feel your package could make use of? In particular, take a look at the $Text associated with the “Document Commons” container and the “Get Commons Note $ID” function. While my current approach is to provide a simple, minimalist implementation, this approach needs to be tested.
Feel free to reach out to me with questions or suggestions. I can be reached at:
Chuck@Interisle.net
+1 508 277 6439
Hello @echuck,
I just discovered today the “Diagram View” concept and went straight to your video presentation. This is great!
I have been able to install the components in my work tbx (context == graphic novel/world building) and have my first very simple diagram working.
It took me a while to figure out why I could not get the Logging system to work. I have my own logging in place and patched the LogReq function to see $LoggingEnabled is seen as false. If I comment the validation line[1], everything seems to work fine.
Checking against the doc[2]: I made sure/Document Commons/LogBooks.$LoggingEnabled == true.
I also have tried to set the attribute is various potential candidate containers such as the prototype of the notes I am linking to the diagram. It is not yet clear to me what the target context of $LoggingEnabled should be. Work in progress.
Going through the presentation, I wondered whether the lack of two-way synch. between diagram and notes would be an issue. The more I think about it, the more I see how powerful your choice of “copy” vs “link” can be.
Once I fully understand the logging mechanism, I’ll happily drop mine: I really like how you can create log containers dynamically.
Thanks again for sharing, this is amazing work:)
Philippe
[1]
//if (!$LoggingEnabled(log_container)){return(time_stamp);};
[2]
Doc on Stamp: “Stop Logging! This merely unchecks—i.e., sets to false—the $LoggingEnabled attribute for the “/Document Commons/LogBooks” container, which will stop/pause all logging (this is a global setting).”
Apologies for not replying sooner—I’ve been consumed by another project.
Hopefully, you found the documentation for the logging package. This is inside the container:
/Document Commons/Packages/Debugging & Logging Tools/
There is a short ReadMe, and a moderately detailed “Documentation” note that explains the various features of the LogRec function and associated LogBooks notes.
There are lots of examples of using the LogRec function sprinkled throughout my various code notes. However, these are normally controlled by a “debug” switch that will only cause debug log records to be generated when debug==true.
I’ll also mention that I included in the “Essentials” installation portion of the “Document Commons” some stamps and functions that create “safe” paths to notes on the fly. While I don’t make use of this in this release, I’ve left these in place because it can be difficult for new coders to figure out how to work around the problem of confused character semantics (e.g., the forward and backward slashes) when encountered in a note’s $Name.
Let me know if you have any problems working with these tools.
@echuck - will do - thanks.
Hi,
I downloaded what I think is still the latest version of this ( Document Commons Framework v2•1•1d.tbx) a couple of days ago and started playing with it. It really is very impressive – thanks very much to everybody involved!
However, I had real difficulty getting the Document View package within it to work – I followed the instructions precisely, including changing the definition of both links, but no matter what I did, the document container was never populated. It took me a couple of hours to work out what was going wrong, and so I’m posting the fix here in case anybody else has the same problem…
It’s our old friend, the ‘smart quote masquerading as a dumb one’, I’m afraid.
I had copied the action code for Diagram←Note directly from the note “Deploying Diagram package to existing Tinderbox document”
Unfortunately, the final quotation mark in that code is a smart quote, not a dumb one, so the action code was refusing to run. Once I’d changed it back to a dumb quote, everything worked perfectly (and impressively!).
BTW, I’ve checked and the error is present in that document in the downloaded version (i.e. it wasn’t introduced by anything I did), so perhaps it could be corrected in the next version?
An easy fix once you realise what’s going on, and I mention it here in case anybody else has the same problem…
Many thanks again for a very impressive project!
@brookter David,
Thank you for finding and reporting this glitch. I have uploaded version 2•1•1e of this Document (see original posting) that corrects the text in “Deploying Diagram package to existing Tinderbox document” note to properly use a straight quote in the action code that needs to be copied into the link type “Action” field.
While I try to be very careful in my use of straight and curly quotes, my presbyopia sometimes makes it hard for me to tell which quote type is being displayed. My apologies for causing you to waste time tracking down this problem. Hopefully, you’ve saved others from the same frustrating exercise.
I believe @eastgate has provided enhancements that will allow me to eliminate this manual step in deploying the Diagram View links into existing documents. I will attempt to release an updated version of the Package Manager and Diagram View soon to take advantage of some of the many enhancements that have been introduced into Tinderbox over the past year.
I do appreciate your kind words, and I hope this tool is helpful in your Tinderbox work.
Given how much work I know went into this this project and the ease† of stray quotes styles, the above is a vey generous response—and quite in keeping with this community.
Thanks and Season’s Greetings to @echuck
†. We might think it would be obvious by context where a “ should be a "—but is the difference obvious to the eye?
I think it will be very helpful indeed, thank you very much!
No worries about the stray smart quote – they are so difficult to track down and it’s the sort of thing you can stare at for hours and not notice.
Best wishes and thanks again!
